Black Jones loops, they are 660mm but fitted with control tech 20mm extensions* which makes them 690mm ish c2c
including ESI long chunky grips which I actually had to cut down slightly to 170mm to have room for the brakes/shifters
few tiny normal use / fitting marks that should all get covered up anyway
*one of the extensions is bolted in not with its original bolt, it doesn't move but thought I should mention it
£95 posted to your very door or bit less if you collect them from my door
FS: Jones loops
Re: FS: Jones loops
Worth contacting Dave, he's crying out for some and missed the last 2 sets by the skin of his teeth.
Re: FS: Jones loops
will do
Re: FS: Jones loops
Sold to Mr Dave
