FOC: Old Rockshox Reba's 29er 100mm 15mm
Dont know what year they are. They were last on my lads bike and he didn't complain about them but not used for 12 months.
Theyre 29er, 100mm travel, 100mm x 15mm Hub, Post mount brake, lockout, dual air, 178mm taper steerer.
They bounce up and down fine in the garage, no idea how reliable they will be bout they have had regular lower leg services when they were in use. They're filthy and I may or may not bother wiping the dirt off them...
Donate to Feed the bear or Free if you're mean :grin:
Collection from Glossop or East coventry depending on what day
Re: FOC: Old Rockshox Reba's 29er 100mm 15mm
if no one else wants them I will take them and make a donation
However i want them for the motion control cartridge to swap out for the handlebar lockout so i will still end up with some forks I can pass on to someone else and or sell on ebay and donate to the boss,
Its very generous of you
No probs.
Theyve been leaning on a shlf in the garage for a fair while getting in my way.
I didint want to try to sell them as i cant be sure they work properly and cant be bothered to do a proper service and buy a new internal seal kit etc
I expect they're fine, but you know how it is.
Let me know when you want to pick up mate.
Taylor
Post by Taylor »
Bugger, missed them.
taylor, you can have them after me but i will have changed the compression side for lock out with bar lever - the plus side i will also have had to change the oil to do this so you get the forks with a service,
Will PM you both,
