Wheel set DT Swiss 350 disc hubs RR460 db rims. £240 posted.
Hubs are brand new DT Swiss 350 6 bolt disc 32 hole. Rear uses the super reliable 18 point ratchet drive, not pawls. Currently set up 142 x 12mm bolt through. Freehub is 9/10 speed shimano.
Front is 100 x 15mm bolt through front.
I have QR adaptors if you would prefer those (the rear adaptors are used though). 100 x 12mm front adaptors are easy to get hold of.
Rims are brand new DT Swiss R460 db. Light at 460gms and very easy to tubeless. Inner width 19mm. Outer width 21mm weight 450gms.
Spokes are double butted alpina stainless J bend in black.
I built these for a project that isn't happening now. These are a long lasting and bomb proof wheelset for your road or gravel bike. Weights are 980gms rear and 800gms front.
DT Swiss 350 disc R460 db rims tubeless wheels -SOLD
Re: DT Swiss 350 disc R460 db rims tubeless gravel road whee
Sold - logistics pending
