...just for a test fit with parts on a new frame sample, a perfect use for a broken one. Otherwise, WHY, anything going cheap?
WTD - Anything cage or similar, functional or broken...
Re: WTD - Anything cage or similar, functional or broken...
You're welcome to borrow a fully functional plastic anything cage that I'm currently not using, if that helps
That would be great, thanks Nick. I ride near Thame a fair bit so may PM and collect if that's ok?
That's absolutely fine.
I live somewhere where it can safely be left outside for collection at your convenience.
Sounds like you are sorted for this. But I have a set of anything cages.
Welcome to collect from mine too if you want a (much) longer ride to Sheffield. Can provide lodgings too.
There is an Evans a few km from mine though...
Thanks Ian, though that may be a ride too far : )
All I need to do is check the sense of adding anything cages to a couple of locations on a frame. If you were selling the cages I'd be interested if they were 2nd gens or plastic, I'd like to try a pair on the forks anyway but it's not a priority for mu current pack preferences.
Looking to make sure the bottle of Jacks will sling onto your iron horse, James? :)
