Following an ever deepening workshop cleanse, the following are for sale.
1/ Wall mounted workstand. Fasten it to your wall with 4 bolts and work on your bike at a comfortable height. The thing swivels and moves up and down and when not in use will fold (nearly) back to the wall and out of the way. I'd advise not fitting it then placing racking in front of it ... because it'll very rarely get used then, will it? £20 plus £6.50 to post.
2/ A Feedback wheel truing stand. This is a sturdy beast - the base is cast steel, the wheel support aluminium with only the indicators being plastic. Very little if any real use so pretty much like new ... now I've washed the dust off it. £35 plus £6.50 postage.
Could probably combine postage of anyone fancies both.
FS: Wheel truing stand / wall mounted workstand
- 99percentchimp
Re: FS: Wheel truing stand / wall mounted workstand
Hi Stu,
Roughly how long from the wall mount (center of the bar thingy) to the center of the clamp.... just thinking if it would mount on a beam in the shed and be low enough?
Could I pick up when at WRT (need to sign up) to save you posting?
Ta, Mark
Ta, Mark
Conquistador of the pointless
If the wheel truing stand is still about at the WRT, I'll take it.
Anyone else who wants it before me, by all means by my guest.
Mark, centre of clamp to centre of upright is 335mm. Centre of upright back to wall is 85mm.
Rightyo Zip.
Rightyo Zip.
- 99percentchimp
Yes please Stu - can I PPG you the money and grab it at WRT if it's a. not a hassle and b. I'm not too late to enter?Bearbonesnorm wrote:Mark, centre of clamp to centre of upright is 335mm. Centre of upright back to wall is 85mm.
Rightyo Zip.
No trouble Mark. Paypal is stuart@bearbonesbikepacking.co.uk and you've another 2 weeks to enterYes please Stu - can I PPG you the money and grab it at WRT if it's a. not a hassle and b. I'm not too late to enter?
Workstand sold to Mark.
