Wanted Surly Ogre or ECR frame
flash
Post by flash »
Wanted Surly Ogre or ECR frame In small 16", ideally the early one without the silly dropouts. Ta....
BigdummySteve
Re: Wanted Surly Ogre or ECR frame
Post by BigdummySteve »
I’ve a medium ECR and a pair of high heels if they are any use :wink:
flash
Post by flash »
What's the seat tube length CTT? I have a feeling I have a medium Surly already in the stable....
BigdummySteve
flash wrote:What's the seat tube length CTT? I have a feeling I have a medium Surly already in the stable....
I believe it’s 18”
BigdummySteve
If it’s any use my inside leg measurement is 30” in my socks and I had a reasonable amount of seat post, no problems with toe overlap but those huge 29+ wheels do limit seat pack clearance
https://flic.kr/p/XhbGws
flash
Post by flash »
I too have a 30" inside leg, this might work. Does it have the modular dropouts? And can you please measure the seat tube anyway, just to be safe. Would you be willing to sell the frame without forks?
Teetosugars
Post by Teetosugars »
Now that is a thing of beauty..
If I didn’t have a Krampus, I’d be biting yer arm off for that.. :oops:
BigdummySteve
flash wrote:I too have a 30" inside leg, this might work. Does it have the modular dropouts? And can you please measure the seat tube anyway, just to be safe. Would you be willing to sell the frame without forks?
I may sell just the frame depending on price although I found the carbon forks made for a much more forgiving ride
This might help on size
https://flic.kr/p/22Dt7z7
The B.B. drop on the ECR is 80 mm
flash
Post by flash »
Unfortunately I'm pretty sure it's too big for me. Shame it looks spot on otherwise. If you advertise it on Singletrack that'll sell....
BigdummySteve
No problem, I’d swing a leg over a small before ordering if you can, I’m about 5’7” with the same inseam and a small would have been far too cramped. If your local your welcome to come and test fit it. I don’t have the parts to make it rideable but I can fit wheels,bars and saddle
flash
Post by flash »
I've measured it against my small Krampus but the difference looks too much, although my 1x1 has a 19" seat tube. I may be able to get my leg over a medium if our local dealer has one in stock....
flash
Post by flash »
Hi "The_Big_Commute"
I can't reply to your PM. So please email me on pete (AT) fixedbristol (DOT) org (DOT) uk
