Wanted Steel 468mm AC fork
Must have a steerer tube at least 270 long and preferably have bottle bosses, mudguard and low rider mounts but will consider a plain one if the price is right. For my Fargo....
Re: Wanted Steel 468mm AC fork
The Pinnacle Ramin fork is 470mm / 51mm offset, if that helps open up options. Some might have swapped the rigid out for sus.
- BigdummySteve
I may have an ECR fork available in the next week or so, 468 and 47mm offset with thousands of mounts
I think I was trying to disuade you from changing it on your thread! Let me know if you do as I'll be interested however if you could check the steerer length as most surly forks are only 260 uncut which is too short for my purposes.BigdummySteve wrote:I may have an ECR fork available in the next week or so, 468 and 47mm offset with thousands of mounts
Phil
- BigdummySteve
Sorry for the delay, it is indeed 260mm as for as I know
No worries Steve, thanks for checkingBigdummySteve wrote:Sorry for the delay, it is indeed 260mm as for as I know
