Wheel build help.
Ben98
Wheel build help.
Post by Ben98 »
I'm currently looking to buy spokes for my new wheel build, but they are generally about 2mm diameter and the spoke hole diameter of my hubs is 2.5mm, does this matter?
Also, any ideas about the best place to buy spokes?
Many thanks
Ben.
AlasdairMc
Re: Wheel build help.
Post by AlasdairMc »
Ben98 wrote:I'm currently looking to buy spokes for my new wheel build, but they are generally about 2mm diameter and the spoke hole diameter of my hubs is 2.5mm, does this matter?
Many thanks
Ben.
Spoke hole versus spoke width is irrelevant, because the spokes must fit through the holes, and the spoke head is what holds them in place.
In terms of buying spokes, eBay is sometimes good depending on the length you need, but I generally just use my LBS as it's 50p each there.
Dyffers
Post by Dyffers »
If I'm getting 64+ spokes then the German sites are usually cheapest even with a few quid international postage.
https://www.rosebikes.co.uk
https://www.bike-discount.de/en
https://www.bike24.de
Dovebiker
Post by Dovebiker »
If you're not looking for anything fancy, ACI double-butted are great value, half the price of DT Swiss and Sapim alternatives and you'd struggle to tell the difference. Try sdeals.com or cyclebasket
Fat tyre kicker
Post by Fat tyre kicker »
I always use spokesave.co.uk, just got the ones for my 27.5 build,
just over 15 quid for 72 stainless single butted with brass nipples,
Always build up well and great service :-bd
Artie Fufkin
Post by Artie Fufkin »
1+ for the man like Spokesave!
Nothing fancy, just decent stainless spokes that build up well.
Never had a problem.
Gari
Post by Gari »
If your really concerned you could use washers.
Artie Fufkin
Spoke washers are usually used at the rim end of the spoke to spread the losing force on the nipple to a wider area on the rim. The holes being s bit bigger on the hub will not be a problem. The spoke head will find its centre when it is tensioned up.
Gari
Post by Gari »
Artie Fufkin
Stand corrected Gari!!!
Didn't know they were available, you learn something new every day.
Cheers.
Gari
Post by Gari »
They say " every day is a school day "
Apparently :grin:
