Alternatives to Mount Skidmore adaptor
Hi folks
Anyone know of anything I can buy in the UK that does the same job as the Mount Skidmore adaptor ??
- JohnClimber
Re: Alternatives to Mount Skidmore adaptor
Why not buy the Mount Skidmore one?
They are only pence and arrive in around 7 to 10 days from the other side of the world.
Great product and service
If that's all the time it takes I might just do that. I couldn't find any delivery info on their site, just expected it to take a lot longer. Cheers
How much you need to move your bosses ?
http://www.tritoncycles.co.uk/accessori ... 0wod6RcHOg give about 8-10 mm of adjustment.
Trail rat... thanks but I need to move quite a bit down to accommodate a MYOG half frame bag I've made.
Zippy...no, I'd just make an arse of it!
Cheers!!
Cheers!!
If got a brand new one in its packet with all the fittings which I'll post for a tenner.
Arggghh. .. I ordered one last night!! Thanks anyway for the offer Ian.
ianfitz wrote:If got a brand new one in its packet with all the fittings which I'll post for a tenner.
DMR do clamps that you can fit anywhere on a circular tube - http://www.wiggle.co.uk/dmr-hinged-clamps-1/ , I've got a pair for the bottle cage on my Solaris as I needed to move it down quite a way. There's also the Zefal Gizmo http://www.amazon.co.uk/Zefal-Gizmo-Uni ... B007VIDC7C I use this on the front of my seat post.
Thanks for the suggestions, but can I ask now about adding a bottle cage mount to the underside of the down tube? I've tried the elite straps Ben mentions but I'm not 100% happy with them. Would the DMR clamps work well for this? What do you folks use?
The DMR clamps basically provide a movable boss so you can just mount a bottle cage in the same manner as you would with the in-built ones on your frame. They are just as secure.
If you take some Jubiliee clips - some old tube to protect your frame - and a Salsa Nickless Cage - you can run the clip through the back of the braces on the cage, which then tighten up, on the no slip surface of the tube, and you get a nice under DT bottle cage. I've used it when I want to get a bottle cage further back on certain frames.petemaz wrote:Thanks for the suggestions, but can I ask now about adding a bottle cage mount to the underside of the down tube? I've tried the elite straps Ben mentions but I'm not 100% happy with them. Would the DMR clamps work well for this? What do you folks use?
jubalee clip hash up - but it worked well didnt lose my bottle once over 5 days in the highlands.
Yeah jubilee clips might just do the job. Cheers!
