download a route and send to gps help
windjammer
Post by windjammer »
having problems sending this route to my garmin gps64 https://moorsonehundred.com/the-route
how do you do this kind of thing
windjammer
Re: download a route and send to gps help
the route has 324 waypoints but my gps can only take 250,how do you reduce the waypoints
I use Garmin Basecamp to reduce the number of waypoints.
You can then upload it to your GPS
Alternatively, use Basecamp to convert it to a GPS track rather than a Route and you then get around the 250 Waypoint limit. You lose turn warnings but can still see the track on your screen/map so you know if you've gone awry.
In Reverse
Post by In Reverse »
windjammer wrote:having problems sending this route to my garmin gps64 https://moorsonehundred.com/the-route
Upload it into bikehike Matt then save it as a gps track.
http://www.bikehike.co.uk/mapview.php
Asposium
Post by Asposium »
this is the route as a garmin course
any use?
https://connect.garmin.com/modern/course/20199507
