Would you like a Stooge?
Potentially, a cheap one? I'm sure you would. The WRT is your chance to own a Stooge for less than it might otherwise cost. We'll be holding a sealed- bid auction for a Stooge on Saturday morning ... simply write your bid, name and number on a slip and post it in the 'ballot box' and if yours is the highest bid, you win.
Don't worry, you won't be expected to have the cash on you. With a little luck the winning bid will be enough to see the amount raised this year for the Air Ambulance top 4 grand :-bd
