Straightening Mech Hangers, Help Needed.
Well the new hanger has arrived so I now have two spare bent hangers.
I have very limited tools and no vice so I was wondering if anybody that did have the tools would fancy having a try to see if they could straighten them for me.
If you could help please drop me a message and I'll post them to you with a return envelope.
I asked the local shop and they didn't want to try, but could order me a new one!
d
d
Re: Straightening Mech Hangers, Help Needed.
I'm guessing that if they are replaceable hangers then they are aluminium? This being the case I would probably bin them; aluminium will weaken under bending and may subsequently fail.
I have a blowtorch and a vice I don't mind using. Not promising anything mind, so if I break them, or they break straight away in use - I will not be held accountable!
But yeah, if they're cheaper alu ones, I'd bin them.
The manufacturer said they should bend straight when I sent them some pictures. I'm happy to take the chance as ideal they will just be emergency back up ones incase I bugger this new one up.Zippy wrote:I have a blowtorch and a vice I don't mind using. Not promising anything mind, so if I break them, or they break straight away in use - I will not be held accountable!
Zippy that would be great, I'll PM you.
d
you should be able to straighten them with just the vice , I tend to find aluminium doesn't respond to well to heat unless your really quick with it , you could try remounting them and tweaking them with a pair of adjustables , worked fine on my old giant (its still on running fine after 6 months)
You really need to straighten them when fitted to the bike.
This. Also attach an old rear mech (or just the bolt if you can get it out) so you don't bend the thread at all.ScotRoutes wrote:You really need to straighten them when fitted to the bike.
Doesn't that risk damaging the bike?ScotRoutes wrote:You really need to straighten them when fitted to the bike.
I can understand bend in a vice and check on bike, repeat etc, but when attached the to bike.
On the fat bike the shop took it off and ent it in a vice, refitted and repeated etc, but that's a carbon frame so could be different to an ally frame.
Ideally you need one of these http://www.chainreactioncycles.com/x-to ... prod122319
I wouldn't have thought that one bending and a straightening would significantly weaken the hanger. Usually you get fatigue when you repeatedly bend a bit of metal back and forth. Then again I'm not a metallurgist.
This is the tool used
It's done with the wheel and mech hanger in situ.
If I was in a bike shop and they didn't have one of those I'd take my bike straight back out again.
Perhaps I'm being pedantic, wouldn't be the first time.
What you are trying to acheive is a REAR MECH which is in alignment with the cassette, this will not necessarily be achieved by straightening the mech hanger off the bike . You really need to invest in the tool that I and Scotroutes have suggested. There's no guarantee that after 2 knocks, the frame may be slightly out so you may actually need to align the new hanger to the frame.
What I'm hamfistedly trying to say is DO IT YOURSELF. You will learn by your mistakes, theres little chance of knackering your frame as after all that's what the mech hanger is designed to prevent.
[quote][If I was in a bike shop and they didn't have one of those I'd take my bike straight back out again./quote]
Too right!
Too right!
What I meant was wouldn’t using a vice and pliers mean too much pressure, not the mech tool.
The frame is fine the hanger took most of the bang, not sure how the cage got twisted, he6 ho I seem to have found the last me h in the country this side if Jan and it should arrive tomorrow hopefully.
If you've got a second wheel with a threaded axle, thread it into where the mech would go and use the second wheel as a lever to bend it into line with the one in the bike. It's a hack I use regularly to check mine when servicing it.
It doesn't take much leverage to bend the mechanic hanger so the frame will be fine ,it didn't damage the frame when it bent so it shouldn't damage it when you straighten it
I promise you I'm not a mech hanger alignment tool salesman but using anything else, especially pliers or a bodged homemade tool will entail additional unneccesary bending, further weakening the hanger due to metal fatigue. The correct tool shows you in which direction to bend the hanger, screws into the bolt hole preventing damage and just makes the job much easier. At the risk of aquiring a panda, if you'd ordered the one I suggested last week, you would have it by now and have 2 spare usable hangers and the satisfaction of being able to fix your bike rather than just fit new parts to it.
With all respect to the above poster, the spare wheel hack will also show you which direction you need to bend the hanger to get it straight. As will looking at the alignment of the upper jockey wheel on the mech itself once mounted though not to anything like the same degree of accuracy. But how accurate do you need? Unsurprisingly the answer is accurate enough for your gears to work properly, but not any more than that.
I should mention though that I AM a mech hanger straightening tool salesman. I probably shouldn't mention that I'm often perfectly happy using a 10" adjustable to do the same job.
Depends on what the mech hanger is like - if its machined or forged and has a flat surface (they usually do) then it can be bent back using a vice and a suitable spanner which fits snuggly over the bit you are needing to bend. A big hammer and a machined flat surface works too (used with care ). I'd also aneal it before and after - smear soap on the back, apply blow lamp (or hold over gas stove) gently until soap starts to blacken then remove heat. repeat after bending.
I believe Park say within 4mm.Oli.vert wrote:But how accurate do you need?
10 speed is (in my experience) randomly more picky regarding a straight hanger than other speed derailleur systems.
The 4mm measurement is at the rim not the hanger - https://www.parktool.com/blog/repair-he ... -section-2
- thenorthwind
This is the method I use too (I have an old threaded axle I keep for this purpose, with a locknut 10mm or so from the end that I snug up against the hanger to spread the bending force).If you've got a second wheel with a threaded axle, thread it into where the mech would go and use the second wheel as a lever to bend it into line with the one in the bike. It's a hack I use regularly to check mine when servicing it.
If we're being pedantic, that gives you a different effective error with a different size rimThe 4mm measurement is at the rim not the hanger
- ZeroDarkBivi
Had to do this manually, for the first time ever, and with only a few minutes to closing time in Lagan Bothy Bikes during this years HT550. No tools, just a work stand and some brute force. Wasn't perfect, but good enough for all 12 gears to work without excessive grinding (after re-tuning another 200km down the road). Normally a bit precious about doing things properly, but when needs must, a bodge can do the trick.
Yeah probably should have said that. You're supposed to do it on the same point of the rim to allow for the wheel being out of true.whitestone wrote:The 4mm measurement is at the rim not the hanger - https://www.parktool.com/blog/repair-he ... -section-2
Width of rim doesn't matter as your talking difference against the same point on the same rim.
