can multiple cadence sensors be paired with a garmin Edge 1000 or Fenix 5?
but only one in use at a time.
for cadence sensor on different bikes.
anyone done this?
garmin and multiple cadence sensors
Re: garmin and multiple cadence sensors
Yes it can be pared with an Edge1000, as I have a wahoo sensor and also the sensor on the trainer paired. Can't remember if it can record two lots of datas though.
Asposium wrote:can multiple cadence sensors be paired with a garmin Edge 1000 or Fenix 5?
anyone done this?
Can you not setup different bike profiles that will do that? I have two profiles set up on an edge 800 for different power meters
don't know.ianfitz wrote:Asposium wrote:can multiple cadence sensors be paired with a garmin Edge 1000 or Fenix 5?
anyone done this?
why i'm asking if someone uses multiple garmin cadence sensors
might facebook garmin and ask
Asposium wrote:don't know.ianfitz wrote:Asposium wrote:can multiple cadence sensors be paired with a garmin Edge 1000 or Fenix 5?
anyone done this?
I dont know if the menus are the same but on an 800 you would go to: menu-(spanner symbol)- bike settings-bike profiles there is then bike 1-5 as options. each one of them has ANT+ speed/cadence and power opttions which you can turn on/off, search for or look at the details.
As above, I can't see why not. I have more than two bikes set up on a 810. I have had two bike been ridden at the same time, only one logged on to the 810 and had no conflicts or noticeable interfertence.
Paul
Paul
