Andrew the maker over in the US has a small amount of King Cage drop cages (I understand they are exclusive to him). If you run a tangle style bag, these buy you a little extra space for larger bottles, as they lower the position of the cage..
I ordered two which came in at $51, so they are pretty pricey at about £43 with postage, but were worth a try.
https://www.andrewthemaker.com/shop/kin ... ottle-cage
PSA Andrew the Maker, King cage drop cages
Re: PSA Andrew the Maker, King cage drop cages
Shame they're not side entry ... then you'd actually be able to get your bottle out
