BB Windshield
BB Windshield
Is the BB windshield - not the tapered style - optimised for a certain size of burner/pot?
Re: BB Windshield
Nope, it's universal or 'one size fits nowt'. I do generally ask people if they'd like any alterations making for use with a specific stove / pot, etc.Is the BB windshield - not the tapered style - optimised for a certain size of burner/pot?
Re: BB Windshield
So does it fit inside both 650 and 900 pot?
Re: BB Windshield
In 'standard' guise it's 100mm tall as is the height of the Alpkit 650ml pot. If you wanted one to play nicely with a 650ml, I'd shorten it to 95mm.So does it fit inside both 650 and 900 pot?
Re: BB Windshield
Couple more questions:
What is the optimum stove for a 650 pot and heatshield? I assume all would work but what would work best? How do you stabilise the burners on uneven ground? The shape of them always looks ungainly with rounded bottom corners unless they are wider than they are taller.
Something I have thought about but never tried is using my original Brukit pot, the one with the heat exchanger on the bottom, with a burner type stove.
Would it just clog up with soot?
I am a sucker for old wives tales and one I have heard but not tried is cutting Meths with 10% water to eliminate soot?
Surely this would just sit as a globule in the bottom and not emulsify into the Meths?
Re: BB Windshield
With regard to my stoves, a 22g and a custom tapered shield would be ideal.What is the optimum stove for a 650 pot and heatshield? I assume all would work but what would work best?
They're probably more stable than you think but obviously finding the flatest place to stand them helpsHow do you stabilise the burners on uneven ground? The shape of them always looks ungainly with rounded bottom corners unless they are wider than they are taller.
Don't bother. There's no benefit as far as I can tell.Something I have thought about but never tried is using my original Brukit pot, the one with the heat exchanger on the bottom, with a burner type stove.
No, soot is a byproduct of a poorly functioning stove - which brings us onto ...Would it just clog up with soot?
Soot is produced when the ratio of fuel / air is out in favour of fuel. The lack of air means all the available fuel can't fully burn, hence soot. By adding water you're effectively reducing the amount of fuel available for the air present. When everything's working as it should, there'll be no soot, so no need to add water. Water will mix with meths but the heat out-put from the stove will decrease if you do.one I have heard but not tried is cutting Meths with 10% water to eliminate soot?
Re: BB Windshield
Just remembered this from the distant past: http://bearbonesbikepacking.co.uk/phpBB ... ter#p11113
Re: BB Windshield
Are the tapered windshields in the shop area?
Re: BB Windshield
No, I make them as specials and favours. Probably far easier to sort out anything you want via the medium of email.Are the tapered windshields in the shop area?
Re: BB Windshield
he means the medium of dance, not emailBearbonesnorm wrote:No, I make them as specials and favours. Probably far easier to sort out anything you want via the medium of email.Are the tapered windshields in the shop area?
The tapered windshield helps a lot with the stability of my mug on the 8g stove. I often find it tricky to find somewhere flat enough (flat rocks often act as a heat sink so the stove really struggles)
The only downside to the tapered windshield is you can't see the stove (as the fit is so good for my mug) so it's not always clear if it's on. Not a huge problem though
