Etrex data saving
biggaygibbon
Etrex data saving
Post by biggaygibbon »
Got an Etrex 30x. Has the W Europe basemap on it ( not on SD card).
Is there a way I can get it to save data to the SD card instead of its internal memory? That way it won't matter about it getting full up with 'activities'....
Scattamah
Re: Etrex data saving
Post by Scattamah »
Don't think you can, but you can move the map to the card and free up internal storage. This is what I do with my Etrex20.
And I could be horribly wrong - happy to stand corrected.
biggaygibbon
erm - how do I transfer the basemap to the sd card? Not wanting to delete anything important......
Scattamah
Post by Scattamah »
Plug your device into a computer - you should see "Garmin" (the device storage) and another drive appear (the SD card - mine appears as No Name). Using Explorer/Finder/whateveryoufilemanagewith, navigate into the Garmin folder on the device storage, locate the IMG file and copy it. On the SD card, make a folder called "Garmin" and paste your IMG file(s) in there.
Not a bad idea to take a copy of 'em and drop 'em on your machine/external storage for backup in case you pooch 'em someday and want to drop 'em back on the device.
Hope that helps.
