TOGS......can't be that hard.
Ray Young
Post by Ray Young »
There is quite a bit of interest in Togs on another post but looking at them there is not really a lot to them so I'm challenging all the bodgers out there (including myself) to come up with something that would do the same whilst being cheap, relatively easy to make (no CNC machining :wink: ) and look OK. Post results on here.
Re: TOGS......can't be that hard.
A pair of stubby barends cut down to 2-3cm and mounted in board of the grips would do much the same.
Dr Nick
Post by Dr Nick »
ScotRoutes wrote:A pair of stubby barends cut down to 2-3cm and mounted in board of the grips would do much the same.
I'd had the same thought, but then through laziness bought a pair of TOGS. I'd not realised quite how 'thin' they are - so they don't get in the way when placed between the inner end of the grip ad the brake lever - a bar end (clamp) would be somewhat more intrusive...
be interesting to see what the fine minds of Bear Bones create
jam bo
Post by jam bo »
I had/have a set. couldn't get them tight enough to not rotate out of the way, broke them trying. somewhere in the bottom of my parts bin now.
HaYWiRe
Post by HaYWiRe »
A little more ghetto but what about Sugru or FormCARD melted into shape and stuck into the inner lock ring of grips? (provided they're lock ons)
Atleast if you don't like it they just melt back off.
TheBrownDog
Post by TheBrownDog »
A couple of these things might do it, either with some Sugru moulded over them or just wrapped in lekky tape?
Ray Young
Post by Ray Young »
^^^ Like it :-bd .
TheBrownDog
Ive got some in my garage. Will experiment and report back.
Looks a good candidate for some homebrew 3D printing.
I'll get round to it... Just give me 5 years or so. :lol:
Ray Young
Post by Ray Young »
Well that didn't take long, not finished yet but here we go. A good rummage through the spares box revealed a pair of plastic bodied brake levers of unknown vintage and origin. I used a hacksaw, then a woodwork chisel and finally a file to get the shape. I may have to cut down the width of the clamping area but won't know until I try to fit them.
ImageIMG_20161130_101430299 by youngray50, on Flickr
NIcely done, that was quick!
Ray Young
Post by Ray Young »
Ray Young wrote:ImageIMG_20161130_101430299 by youngray50, on Flickr
Well that didn't quite work as planned. The narrow bit that you loop your thumb round sat too high for it to be comfortable. Removing further bits from the clamping area only resulted in it falling apart. Oh well, try again.
